Question about Solar Phone Charger
1) currently any post with links gets placed into the moderation que, but we will approve it ASAP. So assume the post will eventually appear,
2) the controller dies at 20.01 Volts 36 cells at 75F should only give 19.8v For me, that's way too close to killing the controller.Powerfab top of pole PV mount (2) | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
Okay Mike Thanks Alot, I wasnt sure an will not post multiples posts again.
I think you are right tho. But Im sure in direct sunlight it may not even get that much volts. These are second grade solar cells nothing new. Ive got thousands of them, good for practice.
Closing this topic to avoid any confusion with the original question.SunnyBoy 3000 US, 18 BP Solar 175B panels.Comment
