Cutting solar cells
You guys dont mind if I keep asking questions do you?
I mean, the only thing I enjoy doing is tabbing these cells together & on the side I like to do little expirements.
Im sure most tabbing and Bus can handle a bit of current right for just smaller panels I dont have to worry as much even if I dont have spec.
I will have to do some investigating but asking chinese companies who make them sometimes give me the run around or they have no clue what im talking aboutComment
What im thinking is I need a Array of these tiny Cells creating 3.60 volts and low amp. And create atleast 1 amp out of array of small cells but high voltage. To push high voltage into my mono cell, so in return in creates high wattage.
Unless you can find new and untested materials to construct a more efficient pv cell. That IMO can take billions of dollars and some very sophisticated lab work.Comment
I agree. The technology is such that you will not improve by "adding different things together" but more than likely regress due to the multiple weak components.Comment
Okay I got the tabbing wire or busbar information. the 0.16x1.8mm
So just wondering about how much electrons can go through this. Without degrading the cells and such.
How much current will be allowed to go through this
1, copper: oxygen-free copper content ≥99.97%
2, copper resistivity: OFC ≤0.01724Ωmm2 / m
3, the coating composition: 60% Sn 40% Pb
4, solder melting point: 179-224 ℃
5, coating thickness: 0.01 ~ 0.04mm can be customized, double-sided uniform coating
6, ribbon elongation: soft state ≥25%, ≥15% semi-soft state
7, the width of error: ± 0.05mm thickness error: ± 0.005mm
From the busbar dimensions you can calculate the resistance per meter of busbar. 1 amp will dissipate 1 watt when sent through a 1 ohm resistor, so now you know power dissipated given current.
Now comes the hard part. You have to calculate temperature rise per watt, or degrees C per watt. That's a common spec in electronic devices, but you won't be able to calculate it easily for your application, since things like encapsulant thermal conductivity, soldering method and glass type will influence it. You can test this to see what it actually is.
Once you have that, then determine the hottest temp the cells can tolerate. That will give you maximum amps. 1 amp is 6.241×1018 electrons per second, so now you know how many electrons can safely go through it.Comment
Okay so I should get the Spec sheet of the Cells now?
To test Temperature. I use a Heat Detector Tester to test how hot the cells get When Finished the panel?
Now comes the hard part yes.. Im not sure I understand what to do, and how to calculate this.
For a Guy like me Im not to great at math.
im just wondering how you calculate this
Should I get specs for the Tabbing Wire also? I see you can tell this is for busbar, I wasnt to sure.Comment
You would usually cut a solar cell in half if you want to get more voltage out of the same area (number of original cells). If you only wanted or had 18 cells which each produce 0.5V and you wanted to produce an 18V panel to charge a 12V battery then you could cut the cells in half and connect them all in series thereby creating an 18V panel. The wattage would stay the same as the original combined 18 cells but you would now have 36 cells connected in series.
As far as cutting the cells is concerned, a craft knife works, you just have to be careful.Comment
I suscribed to this forum about cutting cells because I have a question: What happens if I cut the cell in diagonal just to obtain two triangular cells. Would it work? Could they be joined in series?Comment
Cutting cells at home, works, for a while. The stress and micro-cracks initiated with the cutting, will slowly propagate over the entire cell and eventually ruin it. Factory cut cells are annealed after cutting to prevent this. So you can expect a couple years before they go badPowerfab top of pole PV mount (2) | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
