have tried looking around for bad results and cannot find them, but people i know have warned against it.
how safe is it to do a short circuit test on one or more solar cells in order to be able to test the short circuit current before embedding them into an array. have done some tests, without explosions, but would like to get some peoples experience with short circuiting cells or entire panels, does the voltage just drop down to a level way below max power output and cause no damage at all? or is a load required, be it just a shunt or something, in this case am assuming the analogue 20A current meter would be enough for constant current measurements
