80 3 X 6 cells two panels battery requirement
  • knoxgi
    • Oct 2010
    I am planning to build two panels with 36 3 X6 cells for each panel, what battery I should choose? this will be for an off grid power. thanks!
  • Jason
    Administrator
    • Dec 2008
    • 990
    Hello and welcome to Solar Panel Talk!
    I moved your post to a separate thread. Thanks for joining! Someone should be with you shortly.
      Battery sizing.
      First, determine your loads. Then you only want the nightly load to deplete 20% of your battery. So that gives you a size.
      Then you want your solar to be able to recharge the battery from 50% dead to full, in one day, running all the normal loads too.
      And the charger needs to be able to supply about 10% of the battery's capacity rating, to insure a well agitated electrolyte.
      Then you must assume that your will get only 80% of the spec output of the cells.
      Now you can order the cells and build your panel.
      • Jason
        Administrator
        • Dec 2008
        • 990
        moving this thread to "Building Homemade Solar Panels" forum
        • Clean energy seeker
          • Oct 2010
          • 6
          Battery sizing.
          Mike that was very helpful. I try to not discharge my battery no more than 15% ( somewhere around 12.5v) because it takes too long to recharge it back to full. It seems like the deeper the discharge, the slower the rate of recharge too.
          I assume when you say dead battery, you mean discharged 20%.
            I'm allowing for 20% discharge from full, daily. If you have 2 cloudy days, you are now down 40 or 50% from full. When you go below 50%, it really begins to impact the lifetime of the batteries, so you don't want to plan on regular 50% drawdowns.
              • Oct 2010
              • 6
              My charge controller shuts me off at 11v loaded, so if the battery were measured in unloaded voltage, it would probably be, 20% discharge and off it goes. Good feature.
              The advise on the 10% match of the battery to solar panel amperage output sounds good. So I guess if I had a 100ah battery, I would need at least 10a coming in from the panels to get the battery solution boiling good enough to keep the battery in good shape.
