Help for a newbie!
  • jmag
    • Nov 2015
    • 6
    Help for a newbie!
    Hey everyone! As I stated in my "hello" post, I am planning on building a 60 watt 36 cell solar panel for a Christmas present. Could I please get some ideas from you all on what materials I could use for a quality frame? I would ideally like to keep it around $30 or less but don't know if that is realistic (the frame, not the whole solar panel, of course). I am also stuck on the type of soldering I should use, and if I should I buy some high temperature silicone.
    Anyone make a panel using the Sylgard/Qsil, or should I stick to a wood frame/pegboard panel?
    Thanks in advance for any help!
    • 15205
    Hello jmag and welcome to Solar Panel Talk
    I am sure other members that have built a DIY panel will provide you some information on the type solder as well as any other material to use.
      You will have a hard time keeping your material cost that low if you will be using a good encapsulant and glass.
      And to have a reasonably long life of the resulting panel you should figure out a way to pull a vacuum on it while encapsulating to remove as much moisture as possible.
      Using silicone as a sealant is OK but do not use the air curing (vinegar smelling) standard household silicone variety as that will eat you wiring and cell plating.
      • jmag
        • Nov 2015
        • 6
        Thank you for the response! I AM running into the budget problem, like you stated. I want to keep total cost less than $200, but of course, being under that would be great. Any ideas/areas where I could bring the cost down? How would I go about vacuuming out the moisture while encapsulating?
          • 15205
          To vacuum out the moisture will require a very expensive machine. You are now beginning to see that building a quality solar panel may be fun and educational but it is far from being cheap.
          You probably could have gotten a 100 watt manufactured panel for less then that $200. Just sayin.
          • jmag
            • Nov 2015
            • 6
            I know! I know! I try to not look a prices because they make me discouraged, but I am excited to do this project. Vaccuming is out, haha. How about EVA instead of Q-Sil? I'm guessing it would be a much larger pain to work with but is much much cheaper.
