I would let to set up solar powered sprinkled. I am not sure if that is a thing or not but I would love to see if I can do it. Now, I know very little of the maths when it comes to building a panel, would if be a good idea to find a smaller panel and build off of it or should I build my own?
I have this idea
As a genera rule, except for small panels that have to be constructed to fit into a particular odd space, it does not pay to build your own panels.
That can be fun and educational, but should not be seen as the inexpensive route to a working system that will last.
I believe that there are commercial sprinkler controllers that use solar cells and a rechargeable battery instead of replaceable batteries or grid power.
So it is practical as long as the valves are low power consumption.SunnyBoy 3000 US, 18 BP Solar 175B panels. -
So it is practical as long as the valves are low power consumption.[URL="http://greentumble.com/"]Greentumble[/URL]Comment
Depending on what you want to sprinkle, a SHURflo 2088 pump and a 100W solar panel could do the trick for less than $300.Solar Queen
altE StoreComment
Based on what I was reading I was looking at spending more than that for an "idea" haha thanks I will check this out. It isn't a huge yard but I go out of town each week so it helps.[URL="http://greentumble.com/"]Greentumble[/URL]Comment
