Hi all,
I have been playing around with some DIY PV Cells and have come across the following issue while testing the module at low insolation and thought it time to ask for help.
(i currently dont have too much info on the module will try get it...)
At +-400W/m2 the following occurs:
Im not sure if this has something to do with the tester im using something like:
At AM1.5G i get the following using the exact same set, only difference is the irradiance levels.
Not sure if this is an obvious error.
Thanks for help!
Looks like an awesome forum
Thanks for help!
