I have plans to build a solar panel to run my well pump to start.
I am wanting to set it up with batteries and an inverter I plan to use 165 cells in the one panel with a dimension of 6x5 feet.
what wiring am I going to need.
I figure i will need my panel of coarse, and shut of switch, the batteries, and then the inverter.
Is there someone with some sort of input on what I am missing and what I can expect to gain out of this?
