Ok I am the new guy with all the stupid new guy questions......
First I can build build one, I have the skills, just not the knowledge.....yet, that's where you all step in.
I want to build a panel to charge my single (double if it all works out) 12V deep cycle RV battery at a decent rate of speed. We don't use a fridge, we are on LED lights, the bigest draw is the water pump for the shower.
I have watched a few videos on soldering the cells and don't see an issue getting that done or building an enclosure for my needs.
So, is there a list?
What type of cells?
What is the difference in the cells?
Will a cheap charge converter work well enough?
Thanks for your time and effort to help me out, (as well as all the others that have been helped)
Troy
What type of cells?
Troy
