I am following PVWatts version 1 Technical Reference.pdf file, and got stuck at point 10 (System Derates).
The derated DC power output is given as:
Pdc - DC power
ξsys - overall system derate (losses in the system due to nameplate direct current (DC) ratings, Inverter and transformer, mismatch, diodes and connections, DC wiring, alternating current (AC) wiring, soiling, system availability, shading, tracking error, and aging)
But what value should be assigned to inverter efficiency at maximum power (ηinv)?
Is inverter efficiency at maximum power (ηinv) in fact inverter's and transformer's combined efficiency in converting DC power to AC power:
Thank you for the reply.
P'dc = Pdc * ξsys / ηinv
