I am currently using PVWatts online calculator to calculate the AC Energy output.
I was wondering if PVWatts can be used to calculate how much AC Energy will particular surface(pv panel) output?
By default PVWatts uses 4 kW DC rating system. In the help pages, there stands that 4kW corresponds to a PV array area of approximately 35 m2 (377 ft2). Based on this ratio, can I use the initial area of my surface, then convert it to kW, and do the calculation? In this way I would exactly know how much AC Energy could my specific surface (say roof top) generate ? Example:
Let's say I have an area of 200 ft2 I would like to populate (it does not matter if there are no pv panels which could exactly populate that area. So this is only an assumption):
(4kW * 200 ft2)/377 ft2 = 2.12kW
So for initial area of 200 ft2, I should use 2.12kW as DC rating for PVWatts calculator.
Is this approach not correct?
Just to mention that I am currently not interested in shading. I just want to know how much AC Energy can pv panels/arrays of certain area generate.
Thank you.
Thank you.
