Hello there solar Fellows,
I am planning to build my first solar system with the following specification. However I am wondering if you can help to clear couples question I am having regarding the voltage between the panel and the charge controller
Cells specifications
Rated power : 4 Wp
Open circuit voltage: 0.610v -0.621v
Short circuit current: 7.65 amp - 7.95 amp
Operating voltage: 0.519 v - 0.528 v
Operating current: 6.12 amp -6.44 amp
Panel setup
Wire: Series
Cells: 36
P = I*V =>
I = P/V
I = 4 wp/0.528v
I = 7.57 amp
V = wp/I
V = 4wp/7.57amp
V = 0.528V
Panel outputs:
I = 7.57 amp
V = 36 * 0.528V = 19.008V
Watt = 7.57amp * 19.008V = 143.89056 wp
Charge controller
Brand: Renogy
Rated solar input: 10A/20A
Rated Load: 10A/20A
25% Overload: 1 minute
Load disconnect: 11.1V
Load reconnect: 12.6V
So far so good until here, as you can see the panel output will be 19.008V but the controller is 12V. I am wondering if the charge control will burn if I connect the PV panel to it.
Thank in advance for your help
Sergio
Rated power : 4 Wp
Panel setup
Wire: Series
Cells: 36
P = I*V =>
I = P/V
I = 4 wp/0.528v
I = 7.57 amp
V = wp/I
V = 4wp/7.57amp
V = 0.528V
Panel outputs:
I = 7.57 amp
Charge controller
Brand: Renogy
Rated Load: 10A/20A
Sergio
