OK, newbie here... My project is entirely just for fun and learning purposes. I built a little temperature logger (a common first project, lol) and wanted to experiment with how well I could run it off solar outside. Note that I'm doing everything from scratch. I want it to be a really good learning experience.
I ordered two of these cheapies: http://www.parallax.com/product/750-00030
What I need is to stay above 5V. Now, in full sun, these babies work great. I can even just run off one of them and it's enough to both run my board and charge some batteries at the same time. As long as I have a couple of hours of full sun per day, my circuit runs seemingly indefinitely. The batteries kick in at night and a diode cuts off the panel.
OK, now the problem is that starting at this time of year and lasting until around March, the sun moves just enough that I can no longer get any full sun at all. I live in an apartment building and my balcony is recessed and north-facing, and I'm in the northern hemisphere. Sooooo, starting about 2 days ago, I started losing power. The positive side of this is that clearly, things really were working great before and it wasn't just my imagination.
Without the panel(s), my circuit dies in about 24 hours when the batteries run out.
I have tried putting the panels in parallel and series but got nothing. As soon as I turn my board on with a single panel, I go from about 5ish volts down to 1.4V. Shade KILLS it. In series, I get about 11V open circuit, but around 2V closed. Ouch, but at least it's going up? I could conceivably just keep adding more and more of these things, although I'll have to build a buck converter for when spring eventually rolls around or my batteries will take a serious hit.
So what I'm looking for thoughts on is just how to deal with shade. Just keep adding more panels? I worry that I might fill my balcony up and still not be able to run my tiny little board. Is there something *else* I can do?
I thought of jumping up to a better quality panel, such as *maybe* this: http://www.parallax.com/product/750-00032
But I don't know if it is actually better. I don't know how to compare them. They all give their open and closed circuit voltages and aperages, which is great, but those are based on full sun.
I'm open to other products, too. Parallax is just convenient for small projects.
