Hi All,
I just noticed i have posted my question in wrong thread, so here it is again.
I have built my own 20V 8A - 160W monocristaline panel. Putted some bypass diodes (45V 15A schottky) between bus wires, between arrays of cells, (3 total in panel) and all flooded with silgard.
For now, all looks fine but i have a plan to connect more panels together.
Now, i have a plan to build/connect 8 panels in total (8 x 160W panel), and since i have already putted bypass diodes in 1st panel (45V 15A), after i connect 4 panels in parallel (32A) and then connect another array of 4 panels in series i'll have around 40V 32A total. Now to my knowledge, this is also the voltage/current that will be passing through each panel.
MY QUESTION:
1. What will happen with diodes from 1st panel, will the survive?
2. Can You please recommend what kind of diodes/fuses to use as a bypass between panels ?
I appreciate all answer.
Thank You all very much.
MY QUESTION:
