I'm Back!
6 months later, I did some research and remembered about this forum
Here is an update on the project, which is now quite different.
I just received a Sharp Nt-185-U1 185 watt panel for free, and I hope to create a roof rack mount for my car.
There are lots of things I need to do:
1) Safety: When I received the panel, the + and - wires were connected. Does this short the panel so it cannot create anything but heat? When I build the charge station, I need to make the wire leads longer. The panel puts out 40 volts, so I will have it travel into the car on 40 volts, with the charge controller inside the car. Any outside wires will be weatherproof. I also need to add the correct diodes for reverse current, and fuses to prevent bad short circuits.
2)My 10Ah battery works well for fpv flying all day, but is not nearly suitable for this panel. Neither is the car battery. I will need to find a larger capacity battery bank .185watt/12V= 15.4 amps, so 154 Ah battery bank would be sufficient. Not quite sure where I can find that much battery without spending all my money.
3) Find 200 watt charge controller, supports 40 volt input, steps down to 16V or so.
4) Mount panel to my roof rack. It needs to be easily removable, and possibly hinged. Best case is the solar panel can put on by 2 people, and with just a wrench. Front bar is hinged, and the panel can be angled up at around 45 degrees with ease.
I hope to complete this project around May.
