Hi. I am trying to make a portable home-built solar panel to power a video receiver and charger. I calculated the consumption to be 72 watts off a field battery. I am going to run the gear off a 12V 10Ah battery from a wheelchair. Normally, the 10Ah battery would go dead in 2 hours, but a 72 watt solar panel should keep the battery topped off.
Using the assumption of more is better, I want to build a 100watt solar panel, that folds and fits in a backpack. I will use a coroplast as a backing (cardboard but plastic). I can reinforce it with wood around the edges. Each panel will be about 10x12, and they will be taped together to fold into a backpack.
I have looked all over, and can't seem to find a reliable seller of just PV cells. I spoke to a local company, and they only sold panels. I hope to find cells for under $1/watt. Any suggestions?
If I can find reasonably priced cells, I will do a build on here with pictures
