i have a 500VA inverter with a 12V 100AH Battery which charges from AC mains (220V). Is it possible for me to have a 100 W solar panel with a suitable battery charge controller to charge the above battery with optional charging from mains. i am just one month old to solar so pls excuse if it is a stupid question.
Is Panel possible with current setup
Welcome.
A 100w panel, if it is voltage matched to your system, would take several hours of sunlight to recharge the 100a battery. It would be slow, but not impossible.Powerfab top of pole PV mount (2) | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
Yes it will workNABCEP certified Technical Sales Professional
