Solar system review
    Originally posted by mikejh
    I am going to connect two panels in parallels and two in series, thus boosting the voltage to a better level for the charge controller, and reducing the amps on the wire back, but I am not positive how to wire this. Is there a site, or some diagram that would help me with this?
    DANGER Will Robinson !
    To learn this stuff, you really need to have a basic electricity course. If you just "ape" a sketch of a wireing diagram, and don't see a blatant typo in it, or make your own typo, you can really mess yourself and your gear, up big time.
    It's about the same as watching a video once on how to re-line brakes, and then buying the tools and parts. While you may get things apart and back together, if you don't notice you kinked the brake line, you get to learn an expensive mistake the first red light you blast though.
    See photo 10 on this site for a good idea of what's needed.
    • mikejh
      • Aug 2011
      • 44
      #62
      I have done quite a bit of electrical work, but being that this is my first solar project, I don't want to blow my panels up! Here is what I think I should do:
      Is that correct?
        It's correct if you want 3 panels in parallel, and one in series. ??
        • mikejh
          • Aug 2011
          • 44
          #64
          Haha. Sorry about that, I just drew it up on MS Paint and copied and paisted the panels. Yes, I would do two in series and two in parralels.
