Solar low amp output
  • onlinejames
    • Jan 2022
    • 5
    I have 4 ( 300watt, 24 voc, maximum amp 15), panels connected in parallel. they are only solraiser panels
    I have a Epever tracer AN 40a MPPT controller, to a 200 amp hour 12v battery
    When i have direct sunlight on the panels i only get 21v, 5.8amps into the controller from the panels max, then 14.5v 8.4a to the battery, most of the time i only see 2 amps from the panels
    This seems really low, am I missing something here or does this seem correct?
    These panels are a couple of years old
    Hello onlinejames and welcome to Solar Panel Talk
    When batteries start to "fill up" or get close to 80% SOC the charge controller will reduce the charging amps and voltage going to them. There is usually confusion for people that first set up their system so don't be worried yet. Also 1200 watts charging a 200Ah 12V battery with an MPPT CC may be too much for it. It really only needs about 20amps and what you have may cause it to charge too fast and get to full too quickly.
    You should be able to get close to the Imp x 4 from those panels when the battery needs to be charged but if not it could be how they are wired and exactly how much sunlight is hitting them. Remember that in the Winter time the sun is lower in the sky and will not provide a lot of usable sunlight for solar. Also the age of the panel may cause them to put out less then the rated amount.
    Oh I forgot to ask. Since you have 4 panels wired in parallel, do you have a combiner box with separate fusing for each panel. If so you might want to check to see if any fuses are bad. A bad fuse will reduce the amount of charging amps going to the CC.
    • onlinejames
      • Jan 2022
      • 5
      Hi suneagle and thanks for the reply
      all panels are just joined by splitter cables like these
      https://www.autoelec.com.au/atem-pow...waAj1-EALw_wcB
      that's the problem though with 1200watts, im only showing 4 to 6 amps to the controller max- in direct sun , i would expect 20 amps from 4 panels?
      I even tried it on a flat battery and i get the same, so i don't think its because the battery is too full.
      this is what i am getting full sun 30 degree day, no shade just sun.off 4 x 300w panels
        If you have a combiner box then you can "turn off" each panel and see what it is providing. My guess is that one or more panels are either wired incorrectly or they are bad which is dropping the output.
        It is a little hard to troubleshoot a system this way. All I can do is suggest something for you to try but I would break down the system and check each component and then build it up to see what is happening. You might be able to determine what part is causing the issue.
        • littleharbor2
          • Jan 2016
          • 231
          From the looks of it your batteries are full and cannot take much current. Turn off the charging sources and allow the battery to drain into the low 12.xx volt range and reconnect the panels around noon. You should see full available current from your panels then. You mentioned you tried on another battery. Are you disconnecting the solar panels first and connecting the battery first to allow the controller to reboot before reconnecting your panels?
          • onlinejames
            • Jan 2022
            • 5
            Yes, i disconnect everything, then connected a low voltage battery, then connected solar panels, did very little in the way of amps in
            • onlinejames
              • Jan 2022
              • 5
              I connected each panel by itself which gave roughly the same output to the controller, im starting to think the panels are at the end of their lifespan, although they are only a few years old
              They were just cheap ebay panels.
              even if the battery is fully charged, the controller would only output the required amperage to the battery, the controller should show the input from the panels to what they are producing, or am i wrong in this?
              If the panels are producing 16-18volts at 5 amps, why would the controller show 1 amp or less input amperage?
                • 5209
                Must be an MPPT charger since battery current is higher than panel current.
                With a discharged battery, I would try a DC clamp on ammeter on each panel
                and see if they are quite unequal. Check the weak one. Bruce Roe
                • chrisski
                  • May 2020
                  • 571
                  THat seems to be about a fraction of what you should see. I am at about the same latitude as you and see more than that, even on my flat panels not pointed at the sun.
                  At this time of year with the sun is so low to the ground, from 1200 watts of panels, I would expect to receive 72 amps if the panels were oriented at the sun in both angle and azimuth, and perhaps 30 amps if they were flat. My rule of thumb 6 amps can be sent to the batteries for each 100 watts of panels. On my portable panels that can go into the sun, I see this. If they are the ones flat on my roof, I will only get 2 or 3 amps. Especially in the shorter days of the year.
                  • littleharbor2
                    • Jan 2016
                    • 231
                    One thing that doesn't look right is the low voltage coming from the 300 watt panels. Could you have the polarity crossed in one or more of them?
                      I agree. The OP has some issue either with the panels, wiring or CC because that readout is crazy low.
