Hello, I'm new here, looking for advice on a small project I'd like to either do myself, or hire someone to do, depending on what I learn. I have a 12 year old 2.85 kWp grid tied system, consisting of 15 Evergreen 195W panels and and Sunny Boy 4000US inverter. It's been great, no problems all these years. Our utility company has filed for bankruptcy after their infrastructure caused too many devastating fires, so now they have begun to shut off power during high risk conditions.
After exploring the options, I decided that for our family, rather than investing in major upgrades to our entire system, using our 2013 Prius as a simple generator will be enough to get us through these outages with minimal noise and without having to maintain a dedicated generator and store gas, (other than what we're already storing in the car's gas tank, obviously). Today I installed wiring on the Prius and tested it with our new inverter. So far, so good.
Rather than running extension cables from the car all over the house, I would really like to wire a simple transfer switch or, better yet, an interlock breaker to my main panel, as that seems cleaner all the way around. I'm concerned that the power coming in from the generator will be somehow incompatible with the solar panels or inverter though, and like I said, they've been working so well all these years, I would hate to muck that up as a result of taking on this project without proper knowledge of the consequences.
So, my question is, if I follow the instructions for installing a transfer switch to my home circuits, obviously I would need to disconnect power coming from the inverter during installation, but would I just ignore the fact that there is a grid tied solar system when enabling generator power to flow to the panel during a power outage? Do I need to modify the way my solar system is wired? Do I need to shut off the backfeed breaker before turning on power from the generator? Is it safe, or necessary, to shut off the main disconnect switch between the panels and the inverter during a power outage? Is my Sunny Boy 4000US able to recognize that the power from my car inverter is not the grid, and work as expected?
Right now, my system wiring goes: Panels > Main Disconnect Switch > Inverter > Main panel backfeed breaker switch > Meter > Service pole.
Thanks in advance for reading this. Any thoughts or advice you might have are greatly appreciated.
Joe
Joe
