We have twenty 170-watt panels connected in series in two 10-panel strings. The two strings are connected to a Fronius inverter. One of the panels' glass covers has shattered (for unknown reasons). Can I simply remove it, and run one string with 10 panels and the other with 9? Do two-string inverters require that the voltage from each string be equal, or are these types of grid-tied inverters capable of handling strings of differing voltages?
Unequal number of panels in strings?
The question is,...
Does your inverter have 2 MPPT inputs, or do the solar strings go into one set of terminals ?
And if it does have 2 inputs, will a shortened string have enough voltage to properly run ?Powerfab top of pole PV mount (2) | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
You should be fine with unequal panel counts. The Fronius will treat the strings independently.
It would be best to read the Fronius spec sheet to be sure that 9 panel output voltage fits within the window of the Fronius, but if it is like modern Fronius inverters, you'll be fine.7kW Roof PV, APsystems QS1 micros, Nissan Leaf EVComment
Thanks for the answers. The Fronius was installed in 2014 and it will work with the 9 panel output voltage.Comment
