Hello,
Where is the best location to install a surge protector (Midnite MNSPD-600) specifically to protect a solar array with microinverters?
I will have an 18.47 kW system installed in a couple of months that I am preparing the wiring for it. All panels and micrinverters are routed directly to a combiner box (obviously), then to the utility net meter, then to the disconnect switch, and finally connected to the incoming utility grid. Since I have a "farm panel" (photo attached before reconfiguration) at the main meter outside, there are separate bus bars and my solar array will connect to one of them upstream of my entire main distribution panel for the house inside. There is already an existing whole house surge protector at the house panel.
So, is the best efficiency to install a surge protector for the solar system in the combiner box or next to the breaker where it connects to the utility?
Peace,
Dr. Z.
Peace,
Dr. Z.
