I have made a small motorised field-trolley with a small 24V E-bike geared motor. The battery I use at the moment is a Ni-ion 6S1P 2Ah with Battery Management System (BMS).
For normal use the motor uses ~50W (with bursts of 1-2 minutes I can use up to 140W). After using for 1 hour (mainly parked) the power consumption has been ~ 7-10Wh.
I would like to charge the battery with solar panels to avoid taking the batteries home for recharging - and for fun
. Solar panel charging will ONLY happen when the trolley is in use. When stored the solar panels are disconnect or the trolley is standing in the shed.
I play around with 2x10 W solar panels from eco-worthy that together is giving me ~ 10-14 W at this time of the year.
(Panels are made for trickle charging with a diode)
My question is:
Can I connect the solar panel directly to the battery (and motor controller) with out a solar controller? (to make it as cheap and simple as possible? )
I know it is possible when solar panels are used for trickle charging and the capacity of the batteries are much bigger than what is delivered from the solar panels.
My worries are:
1) Can the motor damage the solar panels when there is no solar charge controller in between ?
2) The solar panels will only be connected when the trolley is in use and the power consumption will then be similar to what I can get from the solarpanels.
At ~24.8V the BMS seems to cut off the connection as my cheap wattmeter goes from ~12W -> 0W. It all seems to work fine but I have a feeling I am missing some important stuff as it all seems too easy and simple?
3) I am considering to use a 7S1P battery (li-ion) to keep the minimum voltage higher. Then I ideally need 29 V for charging. With out having a clue I feel that the solar panel will work better with a 6S1P li-ion battery. Any opinions on this?
4) For solar panel charging it seems that LiFePO4 batteries is the normal/better choice. I know the safety of LFP batteries are higher than for Ni-ion and they do recharge more times, but is there any other reason to choose LFP batteries for this application? (I do like the higher energy density of the Li-Ion cells as small size matters for me. Unfortunately we do not have sunshine everyday and I probably end up with a 5-6Ah battery pack to be able to run the trolley for 3 days with out any sun)
5) Things I haven't though off.
regards Carsten
My question is:
My worries are:
regards Carsten
