Hi guys,
I have almost all aspects of my off-grid solar install figured out now. I'm building an enclosed "closet" to mount on the back of the cabin to put the batteries and electronics in (separated and vented the battery compartment) and now I'm trying to figure out the actual wiring portion.
I have a new tin roof I'm mounting everything on, and so I would like to find a good way to penetrated into the attic space, and then run the PV wiring over to the edge of the house, down the inside of the wall, and pop out the wall inside the electronics enclosure to connect to the charge controller.
My current idea is to drill a 1" hole in the roof, and run an armored cable (like AC90 but in Canada we have Teck90 which is stranded and armored with waterproofing and burial ratings) through the structure up to the whole. I'll use a cable connector to enter the armored cable into the PVC box and then use waterproof glands to enter the Panel's PVU cabling into the same PVC box. Splice cables together, and silicone seal the box to the roof (therefor covering the whole I made for the cabling). my racking sits about 3" about the roof, and the PVC box I have is about 2.5" tall so I'm aiming to put the box below the panels to help minimize sun exposure and help minimize potential for water ingress...
Does this sound like a good idea? What do you guys do?
I didn't think it was a good idea to just run 30' of PVU cable through the ceiling and walls.... In fact I think it's against electrical codes here anyway...
