Hello!
I have an issue with the solar system I am trying to install in my RV. I purchased 2x100W panels from HQST and a morningstar 30 amp charge controller (with lcd screen).
I installed the solar panels in parallel to get the same 12V voltage and supposedly add the amps from both panels.
THe problem is I am getting right now with both panel a reading of about 4 amps jumping up and down of solar amp. It's not a lot and the jumping around seems weird (sun is shining 100% right now).
When i disconnect 1 panel from the pair, I get a very stable 5.2 AMPs on the screen. (both panels outputs about 5.2 amps on their own)
What could be wrong ? I dont get it
I used standard Y MC4 connectors to link them up, and i tried other Y connectors too without any changes.
Thank you!!
Thank you!!
