Substrate and backing material for aluminium panels.....
  • chaitanyapunde
    Hi,
    I have tried a lot to search what is the material that you use as the substrate where you attach your cells and the panel backing in case of an aliminium frame. Kindly assist me. I would prefer non wood materials as it rains a lot here in India and wood wouldnt be a good material for rains.
    Thank You,
    Chaitanya Punde.
    Hi Chaitanypunde - Welcome to Solar Panel Talk!
    One of our DIY types should be along with a response to your query.
    Russ
    • chaitanyapunde
      Hi,
      I am trying to make an Aluminium frame solar photovoltaic panel. I havent started to make it as yet as I am still trying to collect the material I require. I just want to know what do we use as a panel backing and substrate where we attach the cells in case of a Aluminium Panel. Please assist.
      • landslide03
        • Mar 2011
        • 22
        I see alot of people using FRP paneling, it stands for fiberglass reinforced plastic. Home depot and lowes sells them for about $30 for a 4x8 sheet. I think i am going to use them on my panels. I hope this helps!
          I hope so too! Good Luck
          • martinjsto
            • Nov 2010
            • 48
            hi
            I think you are best to use low iron glass if you can get it,it is toughened and opticaly the best for solar applications, you can get it from old rooftop solar hot water systems you just cannot cut it.
            just silicon the aluminium frame around the glass, flip over and either lay your stringed cells face down on the glass and pour the sylgard over top, spread and let it run under the cells. once dry thats it, nothing else needed. you may get air bubble issues and you will learn how to minimise or remove them as you go along. i am going to make a pool of sylgard on the glass first then lay my stings into it and do the final buss wire solder once dry, you can always coat these with sylgard later. hopefully no bubbles.
            if your frame is of decent aluminium of at least 1 inch x 1 ind and either welded or bolted together it will be strong enough once all is set and you will not need any substrate.
            you can always sandwich the cells between EVA layers and lamminate together under vacuum and heat if you have a lamination/vacuum setup large enough, thats how all the profesional pannels are made, with just an aluminium frame around it, the EVA is the substrate and top cover in one. (i think there is a slight difference with the materials used with the top and bottom layer)
            hope this helps.
            Martin
            • multipanel
              Steel materials are the better one for aluminium panel back up which is not effecting or damaging in the rain.
                Pardon? That made no sense.
