Yet, Another RF Noise Question...
    The Inverters generate Differential Mode Noise. That makes it Line Noise. Regardless of the Mode an In-Line Filter on each Micro-Inverter will attenuate both Differential and Common Modes. Common Mode is the radiated noise in reference to Ground.
    My Belly Ache is the damn manufactures could spend $2 in parts to include decent line filters. We are talking 4 capacitors and 2 coils of wire. You can build them easy enough, except they would not comply with local codes and void warranty.
    It took me all of 15 minutes to build one in my Ham Shack installed on the Input of the CC and output of Panels. Tightly twisted conductors and two capacitors work wonders.
      It is all FM to me.
        • 5209
        I'm not talking about low frequency line harmonics; these will not bother the HAM. Radio frequencies need to be contained at the interference
        source, or not at all. Mfrs meet a legal requirement, but it isn't strict enough for a sensitive receiver right there. Often it can be done. When
        my Moms vacuum would wipe out my radio in the 50s, I got hold of it and added some shielding/filtering; no more interference. My 62 car
        generated all sorts of noise in my radio, but I fixed them all. The ignition was the challenge; all the wires had to be shielded all the way
        to the base of the plugs, and power came through feed throughs. Like an aircraft engine. But multiple, unshielded sources are difficult,
        esp on a roof. No need to re invent the wheel; plenty of good filters are available off the shelf. Bruce Roe
        • wb8erj
          • Sep 2015
          • 5
          I installed a small (3kw) solar system on the roof of my house using Enphase M-215 microinverters. I am also a ham, and was very interested in the RFI / interference issue and researched it prior to my installation. On Enphase's tech support section they discuss their recommended installation practices. I followed them, and also added additional ferrite chokes on the output of each microinverter prior to installing the microinverters. My lowband antenna is about 25 ft above my solar panels, and I get no RF interference on my Icom 745 ham radio.
          Here is a link that explains in more detail what I did to reduce the RF interference from my Enphase microinverters I hope this helps!
          -- Mike
          • sdold
            sdold commented
            Editing a comment
            I really liked reading your blog, Mike. I like your "Conserve first, then generate" approach. I'm a ham too and will be setting up an HF station near my Enphase installation at some point, so I appreciate you putting your experiences online. I DIYed mine too.
          • 5209
          Filters can be home built, but off the shelf designs will be more thoroughly proved effective. They start getting a lot
          more expensive after passing perhaps a 20A rating. Inductors work, but they work a lot better when combined with
          capacitors. Just search a little of EMI FILTERS. Bruce Roe
          • wb8erj
            • Sep 2015
            • 5
            Hello, in re-reading this thread, I would like to clear something up with the Enphase M-215 microinverters that I am using, and probably other Enphase products work this way as well. what they do is track the 60 hz sine wave coming from the power company and generate power that tracks that. I don't believe this is the cause of the RFI from the Enphase microinverters.
            I believe the issue with the Enphase creating RFI is coming from their ethernet over power line technology they use to allow the homeowner to monitor their solar panels on the web,. This has a carrier that is injected in to the house power system at 144 kHz. Again, by following Enphase's installation recommendations, and also adding a split core ferrite on the output of each microinverter, seems to kill any harmonic interference generated by the 144 kHz carrier / data transfer that causes interference.
            Here is a link to my page that shows my Enphase M-215 microinverters with an EMI ferrite core installed.
            -- Mike
              • 5209
              A spectrum analyzer could reveal the nature of your noise. The process of tracking the 60 hZ waveform is done by switching
              back and forth in a controlled way, at an ultrasonic frequency. Because the switching is done at the FULL POWER level of the
              inverter input, there is considerable opportunity for harmonic radiation and interference. The right filtering and shielding can
              contain it.
              The communication signal is done at a far, FAR lower power level, though that does not remove it from suspicion. Bruce Roe
                A split-core filter will filter common mode noise but will not be effective against differential noise. The data signal is differential. EMI due to power switch operation is both differential and common mode, but the common mode noise is far more aggravating in real world applications.
                So from your experiments it sounds like the issue is not due to the PLC interface.
                  Just exactly where doe s HO get one of those at? Who is going to teach them how to use it?
                    • 5209
                    I bought several on Eb*y. The prices today are way down, esp as the older ones are pensioned off. Just spotting the
                    fundamental and harmonics of the largest signals isn't very hard. Those who don't really want to know won't make the
                    effort, that includes most home owners. Bruce Roe
                    • fresnoboy
                      • Mar 2016
                      • 50
                      Hey guys. I started a new thread over here: https://www.solarpaneltalk.com/forum...o-interference before seeing this old thread. I am not sure if it's impolite on this forum to restart the old thread or start a new thread for my question?
                      But from the first post you can see I'm trying to decide which solar design to go with for a new house that will not cause HF/VHF interference for my amateur station.
                      On the M215 Enphase units, does anyone have a similar experience on with the new iq units? I need rapid shutdown for NEC 2017 compliance, as well as wanting to use 300+W panels...
                      Thanks, and happy to participate on this or the new thread.
                      thanks
                      mike
                      • Zeigh
                        • Aug 2012
                        • 37
                        UPDATE: Right after this post was started, I had an issue in my life that consumed all of my attention. Thankfully I have rebounded and I am digging into this matter again to the point of becoming glassy-eyed at all the technical details. I have also signed a contract for a solar electric system that includes 52 Enphase IQ7 microinverters and already have prewired from the attic to my electrical utility access. So, instead of starting a new post or trying to decipher this one further, let me simply refine my original question to these queries:
                        1. Has anyone experienced any serious (non-HAM) radio interference problems with a similar system design? My home relies heavily upon non-shielded ethernet connections and Insteon/Z-Wave automation.
                        2. Do I need to do any proactive shielding or filtering for my design? My prewiring is based upon 13 microinverters per 12-3 Romex wiring, so I have a bundle of four wires routed from the attic, through a wiring chase, and across to my electrical panel (total run of about 100-120 feet). Any communication wiring is separated by at least 12 inches, with the exception of a few places where such division was cost-prohibitive.
                        Yes, I get that everyone seems to have their opinions here, but my goal is to shoot for the average consensus. I can still relatively easily reroute all wiring into metal conduit if it would be truly beneficial. Unless I am missing something, that really doesn't seem to be necessary, but want to make sure before it is too late. Otherwise, I am hoping that filtering between the combiner box and utility connection will be all that is needed, if there is even an issue.
                        Peace,
                        Dr. Z.
                        Originally posted by Zeigh
                        Hello,
                        Is it worth enclosing ALL the wiring from my solar panels to the main disconnect switch in metal conduit for RF noise protection? Does it change anything if I am planning to install a Enphase system (micro inverters)?
                        For the first time a few days ago I heard about the RF noise concerns from a friend of mine who is a big HAM radio operator. He sounded like the sky was falling as he commented on my solar panel array installation prewiring (for a 14 kW system with three 12-3 Romex wires run 100 feet to my second story attic). In researching the issue here and elsewhere, I see his concern, but also see the majority of professionals and people allot smarter than I who don't feel this issue is that big of a deal. I don't have any sensitivity to RF noise, nor do I plan to take up HAM radios as a hobby. Still, I am at a point in some remodeling that it wouldn't be too hard to re-route all of my solar panel wiring into metal conduit. It would basically just waste half a day of my time and the additional cost of the conduit.
                        So, what are your comments and/or opinions on this?
                        Peace,
                        Dr. Z.
                          It has been a while since I have had any ZWave stuff but the only suggestion I have for Ethernet wires is to not run them parallet to Romex. If you have to cross them do it at 90 degree angles.
