Yes. 48V to 12V won't cost any more than 24V to 12V.
That would work but it's overkill. Since you are at twice the voltage you will only need half the current. So (1000 watts / 50 volts) = 20 amps. You can get the Midnite Kid controller (an excellent MPPT controller, 30 amps) for $280.
So with 48 volts, then would this charge controller be the size I'm looking for?
