no vibrating table, just supported between two couches with the cushions removed, so i cannot sit on them for 3 to 4 days
 but it allows me to get under the panels to see whats going on
the vacuuming sound like a great way to remove bubbles, not thinking i shook the smaller container of sylgard once before adding it and ended up with the most bubbly mixture, i just work the bubbles out by tapping the mixture and rotating the cups, i use clear plastic cups after mixing the two parts together so i can see all the bubbles
for thinning i use xylene, a 1 part xylene to 3 parts sylgard, and stir till well dissolved before adding the second part of sylgard combo. this appears to work from my limited testing
i am not recommending this method though, for one xylene is very flammable, however once cured there is little to none left, its just to thin it out, after 2 months the panels still look ok, i have tiny bubbles in places, like 1 to 2mm, but can live with that, and the odd pocket where an edge of a cell lifted a bit, but will fix those with extra sylgard once i finish the array
