I am expanding my battery bank to 8x 6 volt 200AH batteries (currently 4). I have a 24 volt system. I will be using series/parallel wiring for the batteries (to bring to 400AH). What is the best way to connect both the wires from the controller to the batteries and from the batteries to the inverter? Do you connect the incoming charge (from the controller) to the same battery posts you use to connect the outgoing current to the inverter? Use different ones? Any help greatly appreciated.
Connecting Batteries to inverter and controller
The CC and the inverter should connect to the same place (but with their own fuses!).
A good start for learning about parallel battery wiring can be found at http://smartgauge.co.uk/batt_con.htmlSunnyBoy 3000 US, 18 BP Solar 175B panels. -
Thanks much. I will check it out.The CC and the inverter should connect to the same place (but with their own fuses!).
A good start for learning about parallel battery wiring can be found at http://smartgauge.co.uk/batt_con.htmlComment
On this same note, is it okay (for convenience, in this case), to tie onto both the terminals and the lugs of your batteries? I have batteries that have both terminals and lugs, and the terminals are rather full, so I was thinking of attaching something onto the lugs.Comment
If those "terminals and lugs" are at the same battery post then it should work. What is the make and model of those batteries so I can find them and see what they look like or post a picture of it.On this same note, is it okay (for convenience, in this case), to tie onto both the terminals and the lugs of your batteries? I have batteries that have both terminals and lugs, and the terminals are rather full, so I was thinking of attaching something onto the lugs.Comment
I have shifted my house from one place to another and i faced problem there for electricity wiring. There light failure is more than 6 hours and i need inverter battery more than 850va. There is not an electrician for long way and charged more. Finally my friends suggest me to buy inverter battery online. I searched in Google and order online to BatteryBhai.com. They gave me free home delivery and installation i'm quite happy. So here i request to all shop inverter and battery online and get benefits at door step services.Comment
