Multilayer, 2 to 8 FPCB & Rigid-Flex PCB
+ More Options
Posts
  • jolindong
    • Jun 2015
    Hi everybody.This is jolin. Does anybody need search PCB supplier.Let me introduce a very good manufacture in china.
    *Huanyu Technology Co.,LTD. has an annual output of precision single-sided, multilayer, HDI, metal substrate and FPC boards more than 1.5 million square meters,
    *Head office in DongGuang over 20 years of experience
    *For your order our production capacity is very strong .for employe over 7,000. Three factory another two for Shengzhen and DongGuang
    *The productiviy of more than 150,000-250,000 square meters/month/factory
    *During the past five years, sales volume has increased more than 30% annually. 2011 annual saleswas0.75 billion yuan, annual sales exceeded 0.9 billion yuan in 2012, 2013 annual sales up to 1.5 billion.
    *theproducts are widely used in communication equipments , mobile phones, computers, medical devices, automotive electronics,detection and control systems,aerospace and military equipments and other fields.
    FPC Parameter
    Tapes of FPC: single-sided,single-sided hollow-out board,double- sided,double-sided boards, 3~6 layered board,Rigid-Flex PCB
    substrate copper thickness of FPC: 8um 12um 17.5um、35um 70um
    Min line width/space: 2mil/2mil
    Min width/space: 4mil(0.10mm)
    Min mechanical drilling hole diameter: 500mm X600mm
    Surface Finishing: ENIG,Immersion Tin,Immersion Sliver,OSP,Gold Finger Plating,Tin Plating,Whole Panel Plating
    HDI Parameter
    Tapes of HDI: 1+N+1 HDI,2+N+2 HDI,3+N+3 HDI,Arbitrary
    Min line width/space:2mil/2mil
    Min mechanical drilling hole diameter: 8mil(0.20mm)
    Min liser drill diameter: 3mil(0.075mm)
    Blind hole's Aspect Ratio: 1:1
    Surface Finishing:
    High-Multilayers Parameter
    Layer Count: 36
    Meterials:Hologen-free materials ,PI Materials,BT materials,ppo,mixed compression,high frequency (Roger、 Arlon\Taconic、Nelco、 Taining,Microwave F4B,Isola...)
    Min drilling hole diameter:8mil(0.20mm)
    Max Aspect Ratio:6:1
    Max finished boare size: 23″* 32″(584mm*812mm)
    Surface Finishing: Lead HASL,Immersion Gold,Immersion Tin,Immersion Sliver,whole panel plating, OSP,HASL,Hard Gold plated,Gold Finger,and mixed surface treatmeat.
    Color of Solder Mask: White,Black,Yellow,Red,Green,Matt
    Special Technology: High-frequencry mixed compression,back drilling,Press fit hole,metal substrates,buried capacitance technology and buried resistance technology
    We are looking forward to establish good business relationship with your company.
    PCB Fabrication
    pcb prototype
    Express PCB
    Rigid-flex PCB Supplier
    Flex PCB
    Aluminium pcb
    Best Regards
    Jolin
    HuanYu Future Printed Circuit Board Technologies Co., Ltd.
    --- Mod Note: No advertising unless you pay. This is your second ad post. Try it again and you will be banned.
    Last edited by inetdog; 06-03-2015, 04:49 AM. Reason: removed ad URL links and contact information.
