Hello All,
I just bought a new charge controller. EPsolar Itracer IT6415ND 60A, 48V.
I am confused/unsure by many things, the most improtant that I need help with is the battery charging settings which seem to me to be too high and gives me the fear that it might damage my battery bank.
I use 4 batteries connected in series for a 48volts system, each of them is 12V.My batteries are sealed 12V 200AH Okaya lead acid batteries.
The settings on the controller are as follows:
High voltage disconnect 64V
Charging limit 60V
Over Voltage reconnect 60V
Eualization voltage 58.4V
Boost voltage 57.6V
Float voltage 55.2V
Boost return voltage 52.8V
Low voltage reconnect 50.4V
Under voltage recover 48.8V
Under voltage warning 48V
Low voltage disconnect 44.4V
Discharge linmits voltage 42.4V.
My alarm is particularly with the high voltage disconnect and charging limits which are 64 and 60V respectively, I felt that sealed 12V batteries shd not go higher than 12.7V at most I.e 50.8 for the 4 batteries. Please help with my confusion as i don't want my batteries explodind.
Charging limit 60V
Boost voltage 57.6V
Float voltage 55.2V
