Hi gang!
I'm new here and sort of new to solar panel systems. I apologize in advance if this turns out to be a long post. I recently installed a solar system on my remote property and it looks like I'm having issues.
Here's the system
Four 170w 12v panels connected in parallel on a sun tracking bracket
Two #2 cables running 140 feet to the controller (I wish it was a shorter run but it is what it is)
The controller is a 60A MPPT
From the controller it goes through a shunt before the batteries. I have a data acquisition unit connected to the shunt to read the amps and to the batteries to read the voltage
24 12V GNB Marathon M12V90 batteries hooked up in parallel
Here's the issue
The MPPT is having issues when it's sunny. When the sun is out the amp readings jump from around 32A to zero. At times it will stay at 32A for a few minutes then it will jump up and down constantly. It's rather frustrating as the batteries aren't getting a good charge. It's fairly stable when it's cloudy but will still jump down to zero amps every so often. After exchanging a number of emails with the manufacturer of the MPPT, he suggested that I put the panels in series. He was thinking the MPPT wasn't getting enough voltage. He says the MPPT can handle the voltage and that should fix the problem. I explained to him that I was seeing the volts coming from the panels on the MPPT display was getting to over 21V. He still thinks this is the solution. So he is saying that the MPPT will still put out the correct voltage for the 12V batteries but the input would be 48V. It just doesn't sound right to me. What do you guys think?
Here are some screen shots from the data acquisition unit. It is set to take readings every 4 seconds. The top line is the amps from the solar panels. The third line down is the amps my equipment is drawing. The bottom line is the battery volts.
Sunrise on a sunny day
Part way through the day
Sunset
Cloudy day
Not sure if the images uploaded correctly. Sorry, I'm new
Here's the system
Here's the issue
Sunset
Cloudy day
