I did a search on 'diodes' to try and answer my own questions but none of the reply's seemed to address my particular issue.
I've read in a few places that bypass diodes are not needed in a 12v set up. Is that true?
If false how many would I need for a 100w, 5amp panel and are there any instructions on the net about installing them?
I understand that blocking diodes are not necessary as the controller will handle back flow but I should install one in each junction box when putting 3 panels in parallel, correct? I saw a video on YouTube about installing blocking diodes so that was helpful. Wish someone had a similar one about bypass diodes.
Thanks as usual
Lux
Thanks as usual
Lux
