Hello,
I have recently installed a small solar system for a home and facing some problem. I am unable to understand the issue and hoping that experts at this forum can help me. Below I am writing all the details of the installation
Installation for home
Installed 1.5kW (6 x 250W) panels with a 2.4kW Single Phase Hybrid Solar Inverter (By hybrid, I mean that it works with grid, solar & batteries with solar being given priority to charge the batteries as well as power the load. If not enough solar power is available then grid power is used to charge the batteries).
Do note that there is no feed-in system; all the energy from solar is either used in the home or stored in the batteries.
In-built solar controller: 50Amps
System Voltage: 24V
Batteries: 2 x 12V 200Ah
Connection: The customer's has a three phase connection. Solar inverter is connected on the one of the phases on which the load that needs to be powered by solar/batteries is connected.
Load: Primarily lights & fans with a small refrigerator (total load is about 1kW)
Problem: Sometimes suddenly lights will go dim or become too bright. Similarly fan speeds will change. Clearly this is because of voltage fluctuation.
There is no fluctuation on other phases and grid voltage is stable.
Any suggestions on how to solve the issue or at least any guesses why voltage fluctuation is happening suddenly?
System Voltage: 24V
