Hello to you all!
I'm a leader in Scouting i lead a group with 12 to 15 year olds. I wanted to make a solar setup for our summer camp because it's on a remote location with no electricity.
This is a picture of the setup: http://img19.imageshack.us/img19/3597/bvab.jpg
This is a link to my solar setup: http://img826.imageshack.us/img826/1959/aiyp.png (file was to big to upload here)
System specs:
You guessed it... i have some problems with it.
When i power a lamp of 100 watts it lights up fine.
When i put on the fridge alone it doesn't work. there is a blinking red light showing up on the power invertor.
So i thought it was too much current 100watts (for fridge)/12vdc = 8.33 Amps
Can i make it work with setting up my batteries in series? 100 watts/ 24vdc = 4.16 Amps
A whole other question:
I want to make a shower too. I bought a bilge pump rated for 1100GHP. the pump operates on 12VDC 3Amps
on the wire is a tape that says connect to + only. The other wire i need to go to the ground. But i don't have a ground connection there. Is it okay i put a 8 foot long steel bar in the ground and connect my ground to that?
All connections are visible in the link i put at the top.
Thanks in advance!
System specs:
- solar panel 36cells
- CMP 12 solar charge controller automatic voltage detection 6V/12V/24V
- 2 battery's 51 Ah each (connected in parallel)
- a power inverter 150watts
Thanks in advance!
