Panesl suit for a inverter
  • nalinpc3
    • Nov 2013
    • 11
    I have a grid tie inverter and specifications are as follows (2 * 500w)
    DC input range-10.8-28V
    MPPT Voltage-15.5-20VDC
    DC MAX current-30A
    And I have cells rated as follows
    Average power - 4Wp
    Average currents 8 I max
    Average voltage- o.5V max
    efficiency 17.75%
    I have 250 pcs of cells
    So.... I need to build panels Can somebody help me to arrange type of panels. I means how many cell I have to put per panel for best operation when considering the mppt action of inverter and in put of inverter etc...
  • Naptown
    • 6880
    36 in series
    • nalinpc3
      • Nov 2013
      • 11
      Thank you
      Originally posted by Naptown
      36 in series
      Can you explain me how to calculate it????/ Wat if I keep Maximum MTTP voltage in each panel and Connect them all parellel to the inverter????
        • 15205
        When you connect each cell in series you add up the voltage. So if each cell is 0.5 volts then 36 in series gets you 18 volts. The amperage stays the same at 8. To get your rough wattage you will multiply the total voltage by the amps. So for your 36 cell panel you would have 18 volts x 8 amp ~ 144 watts.
        You could put more cells in series to get a higher voltage but you can't exceed the max DC voltage input of your inverter. Besides a 36 cell panel is exactly what a standard manufactured "battery" panel has. They are usually configured in 4 rows of 9 cells each.
        • nalinpc3
          • Nov 2013
          • 11
          Thank you very much
          Its a grid tie inverter. Though max current is 30A If I use the panels in parellel to the inverter the current will 24A its ok but wat about the If put 10*4 =20v Still in the voltage range... And mppt voltage also max 20v....... if I use 40 cells and each having 20v and parellel to the inverter is it working????????//
            DC MAX current-30A
            Average power - 4Wp
            efficiency 17.75%
            Just a comment: The voltage range of 15.5 to 20 VDC for an MPPT grid tie inverter is next to ludicrous, and makes me wonder whether you have a plug-in GTI (not a hard-wired connection on the AC side) which is not safety listed and in my opinion is also not safe to use nor likely to deliver close to the published output in any particular situation.
            • nalinpc3
              • Nov 2013
              • 11
              Thank you
              Can just explain me simply. Any way i am going to use it with hard wire connection
                What is the make and model number of the inverter?
                • nalinpc3
                  • Nov 2013
                  • 11
                  back again
                  Its indicated as follows
                  suit for 36 cells solar panel which Vmp is 17-18V as well as Voc is 21-22V
                  wat is the deference between Vmp and Voc
                  Its a chinese one
