Hi,
Im looking for tips or someone who could guide me on connections, perhaps a simple squematic on how to connect two 24 volt panels to a 24 volt pump and two 12 volt fans, the problem in this case are the 12 volt fan wish do not equal the same panels voltage, for that i buyed a dc 24/12 converter. After the two 12 volt batteries wish do i conect first, the pump or the dc converter?
Or so i connect first the 24 pump volts and the converter after the pump to the fans?
Thank you.
Peter
Thank you.
Peter
