we are looking at covers normally they use glass but glass can break polycarbon is thinner and extremely durable has anyone used it?
can you use polycarbonate instead of glass
It has to be museum type of plexiglas. i started off with this type but went to glass. Low iron harden glass.Comment
Polycarbonate not a good choice
Solar panels use tempered, shatter-proof glass. In 30 years, I have never seen a broken one. (I am sure you could break one if you took a hammer to it.) They also have anti-reflective coatings and surface treatments that maximize the light that penetrates to the solar cells. Polycarbonate it not a good choice because it scratches and will over time be damaged by direct sunlight.Jonathan Cole, MBA
Author & Solar Energy Consultant
www.lightontheearth.orgComment
I've seen "laid on the ground" break when driven over, and some mid-west hailstorms can take them out. But generally, up to golf ball size hail, they are OK.
I suppose wind blown tree branches and lawn chairs will do damage too.Powerfab top of pole PV mount (2) | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
