Solarex panels msx 60 about 16 years old the material on back has started to come off. Is there any thing i should be doing? Bloomery
Solar panel backing material
if you are the original owner, and the panels are still under warranty, contact the Mfg.
I might try rubber cement to glue it back, but be advised, it will void warranty.Powerfab top of pole PV mount (2) | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
