I have a 200 watt 24 volt mono panel that is supposed to make 5 amps?
Maximum Power Current (Imp) - 5.4
Now I have some amorphous panels that say this:
Maximum power (Pmax) 43.0W
Voltage at Pmax 71V
Current at Pmax 0.616A
Open-circuit voltage (Voc) 101V
Short-circuit current (Isc) 0.787A
Guaranteed minimum Pmax 38.7W
Only .6 of an amp compared to the 5.4 of a the mono 24v panel?
The manual says: Because these modules are designed specifically for medium and
high-voltage arrays, they can provide savings beyond
their competitive price tags. A 200-volt array, for example,
needs only three modules in series instead of the twelve
needed with traditional modules, which can reduce interconnection
time and materials.
For all I know these things could have been made in the 70's and those numbers are bunk in recent terms.
But what are the advantages of higher volt systems?
In what direction should I be thinking? They are Solarex Millennia. Are they any good?
Voltage at Pmax 71V
time and materials.
