Glass bonded to cells removal
  • jackal
    • May 2010
    • 6
    Hi I'm a newbie here so please allow my ignorance.
    I have just been given two 100 watt panels that has shattered glass. I have not tested them yet but i was hoping to dismantle it to construct a new panel with new glass. The problem I see is that the cell is bonded to the glass but the glas does pick of but leaves some glass behind. My ? is there a way to remove the glass from the panel maybe by dissaolving the glue some how.
    Thank you
    Jackal
    If acetone does not dissolve it, nothing will.
    Highly flammable.
    if in a lighted area, PV micro arcs from cracked cells may ignite the solvent.
    • jackal
      • May 2010
      • 6
      Highly flammable.
      Cheers for that, Im not too fammiliar with the cells but would the acetone affect the cell?
      Ill give it a go though. I might even try some moonsshine
        cells are rinsed after mfg (and many other wafers) win IPA, acetone, and DI.
        It doesn't hurt the rock.
        • jackal
          • May 2010
          • 6
          Nice one Mike
          Jackal
