I'm designing my own panels and wanted to know why cells come in different dimensions even though most are rated with similar volts and amps values. Most I've seen for sale, are 3" x 6". My BP380j panels have about 6" x 6" cells.
Difference between cell sizes
Shapes seem to be a compromise between getting the most out of silicon ingot, the invisible frontside conductive layer that blocks some light, and the conductive traces that absolutely block light.Powerfab top of pole PV mount (2) | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
