I just finished soldering my first 36 cell panel. they have gotten alittle dusty. before i seal my panel with plexi, i would like to clean off each cell. what should i use. just water? dishsoap & water? any ideas? thanks everyone
what do i use to clean my solar cells before i enclose them
window cleaner might be OK, but you might be better off just using compressed air or a can of air like they use to clean computers. Get rough with them, and you'll just start breaking cells.Lawrence Lile, PE -
Treat them like jewels. Use a soft camera lens brush & canned air. Don't let air blast get under a cell and flip/crack it. fingerprints or goo, use a cotton swab with alcohol and let air dry. No windex, no lens cleaner spray, no soapPowerfab top of pole PV mount (2) | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
