Air vent for solar panel
old pipfitr
Actually I use a 3/8 bulkhead fitting with a #150 3/8 ball valve. If your panel is fairly tight the nitrogen will keep the air and moisture out. I have stored prepackaged food [instant potatoes, jelly packets, etc] using nitrogen in 55 gallon drums with sealed lids for 4-6 years with no spoilage. You are actually creating a time capsule. It is an application that I have had success with in the past.Comment
What do they use to seal insulated (double pane) windows with? That works quite well.
Russ[SIGPIC][/SIGPIC]Comment
old pipefitr
There is a moisture proof type silicone that is used by window manufacturers. Contact a window manufacturer in your area and explain what your project is and they will assist you.Comment
But, you are not subjecting your drum to daily heating, chilling, and squirts of water. The pressure/vacuum of such cycling, will quickly purge the N2..... If your panel is fairly tight the nitrogen will keep the air and moisture out. I have stored prepackaged food [instant potatoes, jelly packets, etc] using nitrogen in 55 gallon drums with sealed lids for 4-6 years with no spoilage. You are actually creating a time capsule. It is an application that I have had success with in the past.Powerfab top of pole PV mount (2) | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
old pipefitr
What gave me the idea of creating an inert condition was observing N2 filled outdoor sensors lasting years exposed to different conditions. Many of these sensors were manufactured in the field with glass pipe and brass fittings. It was just a thought.Comment
Mike I believe you but we all can't afford to purchase factory manufactured solar panels. Where I live in the Philippines we have power from 12 noon until 6 in the morning. Power goes off just as I'm ready to watch the US News in the morning.
If my panels fail I will use my battery bank and a charger. Dity is what we try to do!Comment
That's what you should be doing now, if you have power daily, why invest in the solar stuff ?Mike I believe you but we all can't afford to purchase factory manufactured solar panels. Where I live in the Philippines we have power from 12 noon until 6 in the morning. Power goes off just as I'm ready to watch the US News in the morning.
If my panels fail I will use my battery bank and a charger. Dity is what we try to do!Powerfab top of pole PV mount (2) | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
Because one day the Government could stop my retirement check, they have already taken almost everything away that was promised and I feel the need to be self sufficient.
Yes, charging the batteries during the night for day use would work just fine without the panels. Thanks for the link on the batteries earlier post very informative.
What if the Nuclear plants in Japan had solar back up pump operation along with the diesel generators. Diesel generators go offline solar powered UPS goes online.
Maybe no pump cooling failure?Comment
Geeze people have no concept of energy. Because you would have to cover the city in solar panels and a warehouse full of batteries to do the job of a deisel generator.MSEE, PEComment
