Charging a AA battery
I just want something to power the USB while I am not getting direct sunlight. This is just a starter project before I build my first panel.Comment
Maybe a large capacitor would be better? Ther are several solar/battery/portable/USB gadgets out there, building a homemade one will not get you much better. Good learning project.Powerfab top of pole PV mount (2) | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
Would the capacitor be wired in like the battery? Would I need a voltage regulator to control the voltage output?Comment
