Well hello everyone I just joined this forum on yesterday. I started building solar panels several months ago. After buying 6x6 inch cells that were pretty inferior I final settled on the smaller 3x6 inch cells. They do not break as easy though they generally produce less wattage.
I have built two panels of 62 watts each and connected them in series. Each panel has a blocking diode and a 7812 voltage regulator box attached. I get a reading on the out put side of panel (1) of 34-36 volts. Once I connect the panels to a 12 gauge two wire, that runs to my battery bank, the reading before connected to the battery bank is 24.1 volts at 9.5 amps. Two batteries are connected in parallel and then connected to a 2000 watt (4000 watt surge) inverter.
Once I connect the two wire to the batteries the reading drops to 11.9 and slowly rise to about 12.13 over a four hour period. I have been running two big screen TV
