#31 |
The dap sounds like a good alternative. I was searching around last night and found some other possible alternatives.
Sashco (Sealants) 14010 "Through The Roof" Elastomeric Roof Sealant 10.1 Oz. - Clear http://www.acehardwareoutlet.com/pro...rce=GoogleBase Sashco (Sealants) 14004 "Through The Roof" Roof Sealant 1Gal. http://www.acehardwareoutlet.com/pro...rce=GoogleBase CRL Clear Dow Corning Silicone Glazing Sealant http://www.dkhardware.com/product-17...g-sealant.html Elastomeric Epoxies http://www.epoxy.com/elastomeric.aspx |
#32 |
#33 | |
Quote:
#34 |
A 2-part platinum-based (Addition cure) room temperature vulcanizing (rtv) silicone rubber is most suited because during the cure cycle this material will not exude any by-products such as acetic acid and alcohol, both of which are associated with tin-based silicones.
Platinum based systems do not need to be thinned out with any solvents either, and are considered to be archival in the sense that they will not modify or change over time. Solaris® silicone from Smooth-On pours very easily and is totally clear. |
#35 | |
Quote:
Since you seem to be with them, about how much would 30 oz cost? |
#36 |
You are correct.
I come as a friendly contributor; I am willing to offer my 13 years of industrial silicone experience to this industry. But if my presence aggravates you or anyone, then I will stay away from the forum. Honestly, I posted this to see if anyone would respond. So I must apologize, but I do not know the exact price right at this moment as I am at home on Friday night 11;30 pm. We do have pricing though and it will be on our site shortly. Off the top of my head, I can tell you it is VERY competitively priced - less than the DC material for sure. I will post the price soon this coming week... if ok. In the meantime, Would you like to try some? |
#37 | |
Quote:
Great! Sure, I'd even do a test on it with my light meter. |
#38 | |
Quote:
#39 |
So. I got that liquid nails clear seal all mixed together with the mineral spirits. I used a whole tube of liquid nails and and a pint of mineral spirits, half of this:
http://www.homedepot.com/h_d1/N-5yc1...atalogId=10053 I put the mineral spirits in first, then I mixed in the whole tube of clear seal. I stirred it up, and then let it sit all night. The next morning some of the clear seal had settled, so I stirred it again, It resulted in a pretty good mixture, flowed probably as good as sylgard. I poured the mixture kind of like that guy markp on youtube, like this: http://www.youtube.com/watch?v=Muwclw5oYd8 I had the same layout, 4x9, But I went around the outside of the panel, then went down the middle, and then went across each row. Waited, A lot of the bubbles removed them selves because I only went around 3 sides of each cell. Then after most of the air was gone from below the cells, I went down the 2 remaining gaps. Sat some more for most of the mixture to get below the cells then I fished out the bubbles. With the little bit of remaining mix, I poured it over the backs of the cells. It's been sitting for about 2 days, it's still a little wet below the cells. They weren't lying on the tube of liquid nails, It does a little while for it to dry. But, it probably doesn't help that the panel is in my basement. It's not exactly warm or sunny down there. |
#40 |
slow dry is likely better, less stress develops
__________________
Since the dawn of time it has been mankind's dream to blot out the sun. Montgomery Burns http://www.mike-burgess.org/PVinfo_2.html solar:http://tinyurl.com/LMR-Solar gen:http://tinyurl.com/LMR-Lister , http://tinyurl.com/LMR-Lister-Running Water & Power Trenches (+900') http://tinyurl.com/LMR-trenches Powerfab top of pole PV mount | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 400A battery bank | 15, Evergreen ESA 205 fa3 "12V" PV array on pole | Midnight ePanel || VEC1093 12V Charger | Maha C401 aa/aaa Charger | SureSine | Sunsaver MPPT 15A |
