Page 1 of 2 1 2 LastLast
Results 1 to 10 of 12
Thread: Calculating Solar Panel Efficiency
    Default Calculating Solar Panel Efficiency
    I am currently doing a project concerning the efficiency of a solar panel array. I have data concerning the power (kW), energy (kWh), and solar radiation (W/m^2). My problem is that I am not sure exactly how to calculate the efficiency of the panels. I can't seem to find a standard way to do this. Could someone please help me out?
    Appreciate it
    Solar Skipper
    657
    Quote Originally Posted by whitehouse431 View Post
    ... the efficiency of a solar panel array. I have data concerning the power (kW), energy (kWh), and solar radiation (W/m^2). ... how to calculate the efficiency of the panels.
    4
    Efficiency is around 13%.
    Take a panel of mine for example.
    It is 1 meter x 600millimeters (0.6 square meter)
    It is rated at 80 watts peak in 1000 watts per square meter radiation
    80 watts divided by 0.6 gives 133 watts per square meter .
    133 watts at 1000 watts radiation is 13.3%.
    Solar Skipper
    657
    Quote Originally Posted by Mosesbbhhh View Post
    Jun 2009
    Deland, Florida
    125
    The way a solar panel efficency on earth is determined is by how many watts of power is produced in a square meter. 100% on earth is 1,000 watts per square meter. If a solar panel sizes is 2 square meters and the output of the solar panel at 68 degrees F. is 160 watts the solar panel's efficiency is 8%. Temp. and size is always a factor and the output of the panel. Now for the big question. Yes in space the math is different. The formular is 1,500 watts a meter because there is nothing to weaken the sun's energy in space. But Temp is also a factor always to consider.
    Oct 2009
    1
    Default Solar panel efficiency
    Im requesting anyone to suggest which type of equipment or setup I need to measure the actual solar panel efficiency, for example a 120W silicon solar panel
    Aug 2011
    1
    Default Test Question on calulating solar panel efficiency
    I am trying to write a test question related to a brief course on pv. I have the following information, can someone help me understand the calculation?
    The question reads: What is the efficiency of a panel that measures 1m x 1.5m and is rated at 222P max?
    8,632
    Panel efficency is generally rated by exposure to a known source.
    Look up words like INSOLATION sq meter
  9. #9
    hey guys last time I have 12.25kw mounted on my roof facing slightly south of east. Conditions such as temperature and weather affect your output. I can say that in NJ at a lattitude of 41 degrees averaged over the year each one KW of panels produced 1400-1480 KW-hours/year. The longest days have 16 hours and the shortest have 6 hours. My bill has been zero for the year.
  10. #10
    Oct 2011
    1
    Exclamation
    Appreciate it
    how we calculaitng solar panels efficiency
Tags for this Thread
