Results 1 to 2 of 2
Thread: How to connect inverter and Solar Charger controller
    22
    Default How to connect inverter and Solar Charger controller
    Hello guys,
    As anyone knows, the inverter have a DC IN (batteries) to convert to AC. In the case of the solar charger controller we have Solar panel IN, batteries and the Load.
    So anyone have a simple diagram how to connect the Inverter? I just connect the inverter in the batteries and the solar charger controller charge the batteries in the same configuration (without using the load in the charger)
    thanks
    7
    The load connection on a charge controller is only for supplying relatively low power low voltage items, giving protection against draining battery too low.
    However, the charge controller is not designed to provide the sort of current levels required by most inverters. The inverter should take it's DC input direct from the battery.
